Hello Everyone!
So I have had the pool for about 3 months now and I feel like I am sort of getting the hang of pool care.
Here are my numbers this morning for reference:
Chlorine- 11.5
CH - 450
TA - 70
CYA - 70
PH - 7.5 (I added acid yesterday)
Temp - 68.6
My questions are:
I have to add acid(liquid) about every 3 days. Is that normal? I check the PH at least every other day and it always seems to be hovering around 7.8-8.0.
I am using a SWG and my chlorine was always right about 5.5-6 and I thought I had everything running correctly. But, I hadn't checked it in awhile and this morning I got 11.5 and I did the test twice to confirm. Why did it rise so much? Is a colder temperature the cause? I assume I should run the SWG less to lower it, correct?
Last question.
I have these spots that have popped up in the plaster. Are they algae or something wrong with the plaster? The plaster is only 3 months old so I am not sure what they are but they are pretty unsightly. I would say there are about 6 of them ranging from pea to quarter size. Should I contact the builder or is it something I can take care of. For reference the plaster is Wet Edge primera stone.
Chlorine- 11.5
CH - 450
TA - 70
CYA - 70
Temp - 68.6
My questions are:
Last question.
