Results 1 to 10 of 10
Thread: Remove old vinyl patch?
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    I finally found the leftover pieces from my liner install and want to use this material for patching holes in the future, however, I do have a few patches that I have installed that have turned white. My question is, is it possible to remove old patches from the liner? If so, how?
    If old patches can't be or shouldn't be removed, is there any harm in putting a new patch that will match the liner over the white looking old patch?
    Thanks!
    24' Round AGP | 13,600 Gallons | Waterway Cartridge Filter | Waterway 2 Speed Pump | K-2006 Test Kit
    100% Trouble Free Since The Baqua Conversion
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Remove old vinyl patch?
    you can try to remove them, sometimes they come off easy sometimes they can get a little stuck and you risk tearing the hole larger. I would remove them if you can do so, if you can't remove the old patch try to cut off any sections of the old patch that are not laying flat then patch over it. I would just try to peel off the old patch by using your fingernail to work it off, I wouldn't recommend scraping at it with anything sharp
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    fordman's Avatar
    Jul 2009
    Iowa
    119
    sometimes your better of not trying to fix something that isn't broke. If it is holding I would leave it be.
    1988 Ceder Ridge
    24' Doughboy AGP
    Aug 2008
    Conway SC
    101
    Quote Originally Posted by fordman
    LOL, i could see me pulling my patch off the bottom of the pool and there goes all the water..
    17000 Gallons (16x32) Vinyl In Ground Pool
    Sand Filter
    Install "Finish Date" July 30 2014"
    Propane heater installed.. Used for 1 day.
    City Water.
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    Hehe! The patches that I want to take off are stuck on pretty good. I'm scared that the liner will come off with the patch leaving a bigger hole. I think I'll just patch over one and sees how it looks. Just a cosmetic thing anyway. I just don't like seeing the whit spots on the bottom.
    Thanks guys, just wanted to make sure there wasn't some magical way to remove a patch, guess there isn't.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I've had a patch make the whole bigger when trying to pull it off but it's not like it was unpatchable after I removed the patch, just make sure your liner isn't brittle to the point of cracking when attempting to remove it if you can. If the old patch is flat just patch over it.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Don't pull them off, just let mother nature break them down naturally - most cheap clear patches will break down in 3-5 years time, when you see it dangling there - it's time to replace it.
    Also - unless you plan on putting a patch about 1.5" bigger in diameter - I would not put one over top.
    What I find helps remember where all those clear and hard to find patches are is to draw out a patch diagram - draw a top view of the pool, uprights and pump location for reference - any that are on the wall, dot the drawn circle and note how far down the wall they are, any on the floor, dot inside the pool circle and draw an arrow from a bubble that notes measurements from 2 uprights at right angles to one another.
    Hang this diagram in your pool house or on teh garage wall for easy reference.
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    Thanks for the suggestions! However, my 3 patches aren't hard to spot at all. They have all turned white. I have decided to leave the old ones alone and use the liner material that I found for any new holes I might encounter.
    once those white ones lift off and float away - you might have a different outlook on mapping them - white means they won't be sticking much longer til they are gone - maybe 1-2 years.
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    Thanks matt. Mapping the holes is a great idea. I didn't even consider that I might lose track of them when they do come off.
