Hi all,
I have a DE filtered in ground pool. This probably isn't new, I'm just noticing it now, but I see that when I first turn my filter on, for the first 10 minutes or so, air bubbles come out of my 3 return jets (though mostly from one - the farthest one from the filter). I haven't seen any noticeable water loss and my filter seems to work fine, with pressure between 15-20.
I'm pretty sure when first turning on the filter, some air bubbles are expected, but it seems to take about 10ish minutes for them to clear and they mostly are coming from the farthest return jet. My guess is that the DE filter tank is filling up during this time (is that amount of time normal?), but I don't know if there's a bigger problem here.
Is what I'm seeing normal? It's an older filter with older tubing so it's possible there is some leak. I'm just really hoping it's not the underground tubing again. I had an issue last year where the water level would drop a lot when running the filter and one of the jets (again, the farthest one) was blowing dirt into the pool at the start, but I had that professionally fixed and those issues went away.
