Hello all, the fine pool owners on this forum helped me select the Raypak 406K pool heater, which seemed like a great fit for me. Here is a link to that post. New RayPak 406k installed today, tips on how to make it last and work properly?
I had it installed by a professional pool company on August 9th, 2017. I noticed water dripping from the inside of the heater yesterday, and I called the pool company. They came out and said the heat exchanger is leaking, and RayPak says my pool chemicals are to blame, and the will provide a replacement exchanger, but not cover labor. I keep my FC between 4 and 6, sometimes it goes a bit above or below this, and I adjust, pH between 7.2 and 7.8, and my salt is currently 2900ppm. Raypak stated that one or more of these chemicals is the cause of the heat exchanger leaking.
This lead me to do a bit of research on leaking RayPak heat exchangers, and I was dismayed at what I found here: New RayPak 406k installed today, tips on how to make it last and work properly?.
This heater has only been installed since August 9th 2017 and I am not very concerned about the poor quality of the heat exchanger. I think this company knows they have a defective product, and I am even more concerned about how they are choosing the address it (blame the customer).
My question/advice is this.
I do not want to have to replace a defective heat exchanger outside of warranty, EVER. They are expensive, and should last longer than my experience, and the experience that others have posted about here: Top 10 Reviews of Raypak. My fear is even if they replace the exchanger, that based on other customer's experience, it will fail again, possibly outside of warranty, so I leaning towards sending this thing back and getting a different heater, from a different manufacturer.
How would you handle if you were in my situation?
Thank you!
Thank you!
