Just looking at the pool you wouldn't notice any algae, but when I brush some green algae is kicked up and when I clean the cartridges filters there is a light hue of green on the unwashed cartridges. Should my cartridges ever have a green hue if my pool chemistry is correct? Do I need to shock the pool? Here are my specs:
11,500 gal salt water black bottom pool, running filter about 10 hrs a day at 1200 rpm, IC40 set on about 50%, the pool remains covered quite a bit and temps are around 81 - 86 degrees. The pool chemistry is very regularly checked with a taylor 2006 and is as follows:
FC = 8.0 - has been in the range of 7.2 -9 and not dropped below the 7.2
CC = 0 - kind of strange, you think there would be some if there was any noticable algae
PH =7.5
ALK = 90
CA = 390
CYA = 70-75
Salt = 3600
Is there just not enough circulation in my pool, do I need to brush it more often than 2 times a week, do I need to shock the pool? I guess I am just a little miffed as to how there can be any algae at all with the numbers I have. Thanks in advance for your experience and wisdom.
PH =7.5
ALK = 90
CA = 390
CYA = 70-75
Salt = 3600
