Hello,
I have been having issues the last 1-2 seasons in maintaining my FC levels. It seems no matter what I do i'm not able to keep my chlorine at the required levels. This is the first season that I have been majorly involved (Buying chemicals, taking in water samples, etc) with the pool. I have started to get fed up with continuously dumping in chemicals and not getting any result which is why i'm posting on here. As an overview my pool is about 110,000 Liters. I have a variable pump with standard filter, vinyl liner. The pool is located in central Canada - The pool is open from May - September and closed for the rest of the year.
For pool maintenance I have been using Bioguard chemicals. Specifically 6 tablets/week in skimmer, 6 bags of smart shock (Oxidizer)/week and 220ml of banish/week (Algae treatment). In addition i take pool samples in monthly and use other chemicals as required to adjust PH, Total Alk, etc.
This season I noticed the problem after doing shock with power chlor (Trichlor) product as recommended from the pool store. After these shocks I would get my FC to go up but it would not maintain itself for man than 2 days. As a note my CYA level was about 50ppm when I opened the pool up this season and started with the shocks. After a few more attempts the pool store performed a chlorine demand test and determined my pool was in Demand. I followed the instruction from the pool store and purchased 15kg of powerchlor (65% Available Chlorine) and added about 1.5kg in the morning, afternoon and night for 3 days. I took pool samples in every day to check the FC and TC levels. On day 3 I had a FC of 4, TC of 4 - I thought and the pool rep thought the problem was fixed. 4 days went by and my FC went down to .3 and TC was 1. At this point I was ready to throw in the towel. One item to note is that during this entire time we had 0 bathing load. Also, i didn't know this at the time, but because we were using power chlor (A trichlor type of chlorine) I was steadily adding CYA into my pool. By the time I had done all the shocking my CYA was at 150!!! During the entire pool year I only had cloudy water once. The time I did have cloudy water was because of chlorine demand - based on what the pool people said.
At this time it was already the beginning of August. Our next solution was to either do another BIGGER shock or empty the water. I figured that since the season was pretty much over I would empty the pool 70% (water is cheap), shock it, fill it up to winter level. In hindsight I made a mistake of shocking it after I emptied it..I should have waited until it was full so the water would be more diluted and I would have a lower CYA. Anyways, I shocked it with 4 kg of breakpoint 35 (Lithium Chlorlite), which i found it much better to use because it does not affect your CYA. After the application my FC shot up to 8ppm and then in 2 days I was back at 1 FC and 3 TC. At this point I started looking at the forums on this site.
Based on the info above and what I have read on this site I think I have an algae problem that hasn't been fully dealt with. To make the issue worse I don't think the CYA has helped. The article I found on this website to most identify my issue is a respnse from JasonLion (Effects of high CYA on chlorine demand). I have already had arguments with with my pool store regarding CYA.. They seem to think an acceptable level is between 30-ppm and 200-ppm. I have further tried explain that chlorine effectiveness decreases as CYA increased (based on the CYA / Chlorine Chart). They don't even respond. I can't believe they kept pushing me to a Trichlor shock in lieu of a lithium chlorlite. To me this would explain why i'm not able to maintain my FC level. I do question however that at the start of the season I had decent level CYA (50ppm) but still had issues with my FC.
As of today I refilled the pool back up to winter level. The results for the last few days are below. One thing that doesn't make any sense is that my CYA went from 90 to 156 without adding any chemicals. I know it can't be the water since On sept 19th I was at 90 and the pool was mainly filled with city water.
Sept 20th
TC 1.8
FC .5
CYA 156
** Pool was 100% filled to winter level
Sept 19th
FC 3.5
TC 1.7
CYA90
** Pool was 70 % refilled to winter level
Sept 18th
TC 6
TC 3.5
CYA 151
** Pool was 70% drained
Any ideas what I should do? My plan is do a shock treatment with bleach so it's ready for next year. However, at this point i'm not sure what my shock value limit should be considering I got a misreading today but I can likely assume it's lower than 90. I don't have a Tf-100 test kit or a taylor as they are very expensive in Canada. Next year I make look at getting one. For now I will use the pool store testing equipment.
Thank you,
Sept 20th
TC 1.8
FC .5
CYA 156
Sept 19th
FC 3.5
TC 1.7
CYA90
Sept 18th
TC 6
TC 3.5
CYA 151
Thank you,
