Results 1 to 7 of 7
Thread: SWG question while shocking
    I hope this does not sound silly, but here goes...
    When it comes time for me to shock, would I turn the SWG off while I am using bleach to get to the right shock level?
    Thanks for the input!!
    63,000 litre IG Vinyl Pool. 16 x 32 Gemini. Zeobrite filled sand filter. Zodiac Duo Clear 130 Salt System, Hayward Pool Heater.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: SWG question while shocking
    You can use your SWG to help maintain shock level, but it is not useful to 'get' to shock level.
    Use bleach or liquid chlorine to reach shock level.
    Follow the directions in Pool School for How to Shock Your Pool. The last paragraph explains using your SWG to help maintain.
    Post back if you have more questions.
    You're done SLAMing when:
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    I'm not sure what you mean by "when it comes time for me to shock", but I wanted to point out that as long as you can follow the chlorine cya chart, which is easy with an swg, you shouldn't really ever have to shock. This is assuming good filtration, circulation and brushing.
    Reebok: I do not have to shock nor have I had to shock yet. I was just asking this question so that I could be knowledgeable if and when that time comes. We have only had this pool for two and a half months so I am just trying to educate myself for all circumstances.
    Currently my CYA is at 70 and FC is at 3, which is right in line at the moment.
    Thanks too both of you for replying!!
    Jun 2007
    Poughquag, NY
    217
    The few times I've had a problem, I boost my SWG output while adding bleach at the same time. In my case, the cool weather cut my high speed run time down (I have it set up so my multi-speed pump runs slow unless the solar is running) which reduced the amount of chlorine in the pool.
    The bleach gives me an immediate CL boost to fight the cloudiness and bumping up my SWG increases the run time which increases the time that the "shock" level in the SWG cell is working. So far, it has worked for me.
    20 x 40 vinyl IG. SWG. Solar. Ikeric VS pump.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    gotcha, just be careful since you're at the exact minimum fc level.
    tphaggerty: the only problem I see with this is shortened cell life. if you use bleach/chlorine only to shock (without increasing your swg %) you will have an increased cell life. of course the increased life may be measured in only minutes, just depends on how often you do that.
    Jun 2007
    Poughquag, NY
    217
    I agree that it may shorten cell life. But running it at a higher percentage for a day or so isn't that much of a concern to me. I prefer a belt & suspenders approach to clearing any cloudiness - and it seems to work..
