:-D Good morning fordman...You should be able to look for a Hayward pump dealer, in your area, on the internet but I have used the all-thread rod like JohnT described and it worked great. Just get a rod the same diamater as your bolt, use two nuts on one end (tightened towards each other in a jam-nut fashion) and either the same thing on the other end or a single nut and lock-washer. Mine was still holding several years later when I got a different pump. Good luck.
