A number or people on this board pour antifreeze to protect their lines during the winter freeze. I've read recently that antifreeze is heavier than water, So it would naturally sink to the lowest point in your plumbing. If that point is below the freeze depth, then there there doesn't seem to be any benefit. That would be especially true for those people who like to pour antifreeze into their main drain line. My main drain is eight feet down. The water doesn't freeze at that depth.
I took some pictures when I had my pool renovated in April. In the picture below, you'll see one of the skimmer lines running behind the pool light. The line, at that point, appears to be 18 to 20 inches down. Since lowering the water below the top edge of the light is not recommended, what's the point to adding antifreeze? Am I missing something here?
