Hello to everyone! New to TFP! I will try to keep this short and sweet, but I'm afraid that may be a task itself considering my pool has been anything but "Trouble Free". So, just a little background for your understanding of my never ending pool saga..... purchased a pool last summer mainly for our 3 boys ages 10,5&3. (We were BRAND new pool owners at this point and clueless To the pool water chemistry etc., we used the pool last summer for a bit with the addition of chlorine pucks and balancing the PH. Fall rolled around and we pretty much just let it sit. (We had plans of draining and moving to new location for this summer--didn't happen).
Fast forward to this summer.... after being consumed with baseball and playoffs the pool has now been severely neglected. (I know now.... lol). After baseball season ended I PROMISED my boys I would have the pool up and running to enjoy the remainder of the summer in this insane Texas heat! I was so wrong... (first off I should have drained, scrubbed, cleaned, brushed, power washed and or just PLOWED OVER the pool). But... I didn't ?. Too late now to turn back. I went from having the creature from the black lagoon living in my swamp of a pool--- to a now, blue, cloudy pool with I'm sure a disgusting amount of mess on the bottom. We have scooped and scooped and scooped tons of debris, and who knows what from the bottom...(who knew it could smell SO bad). I will spare you the details of all that lurked below the surface. But it appears to all be gone along with the different bugs that made the swamp their home. The pool has been vacuumed, brushed, etc., constantly until my new test kit came in. Test kit in hand and will post results here shortly. (Did I mention the pool was left uncovered after last season??)
Pump & filter were upgraded during this process because don't you know, my pump line broke from old one and flooded the entire yard with pool water after about a week of cleaning. So new pump,new filter,new sand, and converted to saltwater.
Last Friday I added:-roughly 2lbs CYA because it was barely registering. (This level was the result of test strip reading from pool company because that's all that was available)
-5 gallons 10% liquid chlorine bleachfrom Lowes. (Yes, 5 I was slightly irritated at this point to say the least)
- 60oz. Muriatic Acid (liquid) to bring down my TA which was really high. (If I remember correctly it was around 180-200)
Saturday&Sunday we swept,vacuumed,brushed and then hit REPEAT. This was done as much as time would allow both days. Chlorine was added at about 1/4 to 1/2 gallon every 6 hours or so just to keep it high enough to do some work... (while this was a complete guess while waiting for kit to come in). I do say, Saturday morning after the large amount of bleach etc., I could actually see a pretty drastic difference in clarity. It appears their are areas on the bottom of the pool where you can distinguish what is "dirty" and what is not. Although, we still can't see past 18" at this point again... so here are the test results to the best of my knowledge.
PH: 7.2
FC: 5ppm
CC:1.5ppm
TC: 6.5ppm
CH: 325(??) I feel this isn't accurate
CYA:20
TA: I could not get the color to change back to red regardless of droplet count... my 5-way test kit I get a reading of 130-180 (sorry for the inaccuracy in readings)
Please excuse my rookie pool mistakes, and thanks for your patience with this long winded post. I currently have 3 gallons 10% liquid chlorine available to initiate a SLAM but would love for suggestions to make this as effective as possible. I also feel like I have purchased enough other chemicals to make this happen. Really hoping to get the boys in the pool... this is their last week of summer before school starts back.
Thanks again for all the helpful info info on this site!
PH: 7.2
FC: 5ppm
CC:1.5ppm
TC: 6.5ppm
CYA:20
