Hello,
Just refilled Pool because of High CYA and a severe algae bloom.
My TH 100 readings now are :
Free Chlorine 6.5
Combined Chlorine 0.5
PH 7.5
Total Alkalinity 110
Cal Hardness 150
Cyanuric Acid 30
I was hoping to raise my CH later, or else if it is important to get the CH at the proper levels before the SLAM.
This pool chemistry / pool math is all new to me. I believe that I need add the following:
Start off by adding 46 oz of 6% bleach to elevate my free chlorine to 4 to 6 - maintain the FC 4 to 6 keeping this process going 24/7 until
a. CC is 0.5 or lower
b. You pass an OCLT (shows a loss of 1.0 ppm or less)
c. the water is clear.
I Just one to get this right the first time.
Any input or addition advice you be appreciated.
Thank You
Free Chlorine 6.5
PH 7.5
Cal Hardness 150
Cyanuric Acid 30
Thank You
