Hi folks
My pool is plaster and is about 11 months old. Since the pool was constructed I've had an uphill battle keeping the pH in line. The pH increases about .3ppm per day meaning I have to dose with acid every other day best case.
To compound the problem, I live in Phoenix so my water is full of calcium meaning the pH must be 7.6 or less to keep the CSI in check. Ive continued lowering my TA in hopes this would help. Right now I'm at TA 60 and I'm still having major drift issues.
Recently I purchased a Stenner to use for liquid chlorine. I'm at the point of considering using the Stenner for acid instead since the pH demand is much more onerous. Other ideas are lowering the TA to 50 or adding borates.
Any advice from my fellow TFP squad?
