Getting tired of manually cleaning the pool and looking to get a pressure-side cleaner. Is the 280 still the standard? It's what I used to have but I see a few other models now (360, 380) that are belt driven and otherwise different so I figured I check to make sure I'm getting one that will last.
The old booster pump that I've had since I got the house +6yrs ago is still supplying lots of power out of the pressure side return, but it appears to have a leak. Being that it appears so old (its exact age is unknown to me) should I replace the whole thing, or just fix what's broken here? Looks like it's a gasket, but is there anything else I should do to it while I'm fixing that?
Here's some pictures of the make of booster pump, as well as it shooting out quite a stream of water:
