First a quick testimonial/thank you - So I have been putting into practice everything that has been suggested here and the results have been amazing!
Since I got bought my test kit this spring and worked to get my pool levels to where it should be (only took a couple of weeks), the pool looks awesome and I have saved $100's of dollars from running to the pool store and buying what they said I needed or trying to guess when using the test strips and just trying my best. I cant image the mess or expense I would be having now in the summer months without this.
A big thank you to everyone who contributes!
OK, now that we are into the hot summer days this past couple of weeks I am starting to notice that is difficult to keep my FC in range (3-5) for my pool. I have been turning my SWG levels up and it is now at max setting and is running on high speed 24 hours a day. Also the pool has been heavily used the past 2-3 weeks also.
I had to add some water to the pool yesterday and I ran a full test this morning and my CYA level is down a little so I will be adding some stabilizer today and a little salt.
So my question is, am I doing something wrong or it just because of the high usage and high temps? Should I be added a little something to help keep the FC levels up? Water still looks great, but I feel that I am living on the edge.
FYI - Here was my full results from the morning.
FC - 2.5
CC - 0
CH 275
TA 60
CYA 50
PH 7.2
Salt 3800
Also my water temp is at 90 this morning, not sure if that matters at all.
FC - 2.5
CC - 0
CH 275
TA 60
CYA 50
PH 7.2
Salt 3800
