I'm a new member and have been reading here and elsewhere and am in the process of trying to eliminate a high 3.0 ppm combined chlorine reading (using Taylor dpd-fas test).
Initially the CC was 7.5ppm. I added 3 gallons of 12.5% liquid chlorine and 2 cups of 65% Sustain energizer and this combined with a few inches of new rain water have lowered the CC to 3.0. This was very encouraging but subsequent shocking throughout last week did not continue to lower the CC. It got stuck at 3.5.
I let the chlorine fall to ~5ppm over the weekend so that we could use the pool and then the CC mysteriously (to me) dropped from 3.5 to 3.0ppm.
So now it is Monday and I am back at it. At 9:30am I added 3 gallons of 12.5% liquid chlorine running the filter and an aquabot vacuum to mix well. At 1:30pm I measured 23ppm free chlorine and still 3.0 ppm combined chlorine. At this point I added a fourth gallon of liquid chlorine and will test again this evening.
I am testing with only 5Ml sample of water so as to use less reagent so my accuracy is 1ppm per drop.
So am I on the right track? Am I shocking high enough? What level free cl should I maintain going forward?
Thanks in advance, Mike.
