Hello,
I'm new here. I have an original endless pool that is approx 3000-3100 gallons; vinyl liner with a manual roller cover. I did not use it for many years for a variety of reasons, but I have kept the water level up and the pump running twice a day for about an hour each time. No chemicals, no cleaning, heat no other maintenance for at least 3 years; spotty maintenance for 2 previous. I finally decided it's time to clean and use it, or get rid of it.
I live in a very water restricted area, so refilling is not on the top of my list since we quickly jump into tierred expensive pricing over baseline water usage.
About 1-1/2 weeks ago I started cleaning. Installed a new cartridge filter, added shock started to adjust chemistry. Complete disclosure, I just kind of hacked at the chemistry for the first few days. My test kit and strips were old, but I mostly just had cleaning. Water has never been green, just alot of debris and cloudy. I had zero CYA reading and then ran out of that test; reoredered, but was not able to test.
The only supply store available to me is Home Depot. I got 1 packet of 10,000 hdx brand of shock, 4 gallons liquid 6% bleach and a new test kit from them, then ordered Taylor K-2005 refills from Amazon, also purchased Clorox Chlorine Stabilizer 10004CLX and waited.
I've been running the pump (not 24/7), but at least 6-10 hours a day sometimes without the cover, got the pool to 78-80 degrees and balanced - I think.
Aside from the fact that we get a lot of fog, I also have a partially shady back yard, so sunlight is not always present when I have the cover open
My problem - the water is still cloudy and I don't know which tests to trust anymore. Cleaned the filter yesterday and the day before. Just brownish, nothing alarming. No organic material, no algae.
do I just wait this out?
It's been getting incrementally better, but feels like I've reached a plateau on cloudiness.
Also, HDX test kit on chlorine is hughly different than Taylor kit. Both are brand new chemicals. New test strips come in at different readings too.
Today's current stats from Taylor: I had to use the 1.8ml test method.
water temp:78
FC Chl: 7-10 (had to use the 1.8ml and multiplier)
TC: ~10 (color is slightly darker than FC, but not much)
Alk: 110
Ph: 7.5
CYA: 40
Cal hard: ~300 (this is sketchy as the chem's are old and it seems so subjective on color change)
HDX kit shows:
Chlorine at 2-3 (this kit feels a bit like using a hammer to install a tack - no subtly at all)
Ph: 7.6
Alk: 120
Thanks for any advice.
Caitiekay
water temp:78
Alk: 110
Ph: 7.5
CYA: 40
HDX kit shows:
Ph: 7.6
Alk: 120
Caitiekay
