I know, it's pretty gross? I have to say though it was not as bad as I thought since it's five years old. I am primarily the only one and it probably 90% of the time.
OK question for you. I added the Ahh Some exactly as prescribed. I let it run for probably an hour changing my air vents around and having both pumps plus my air pump running. It acted just like I think it was supposed to, creating a nice layer of foam and leaving a film of YUCK. �� I drained it and wiped down the surface line of Gunk and continued to wash the hot tub and rinse it all the way till it was drained. After it was drained I sucked it dry with my shop vac. I then took my water hose and blew through all the Jets and rinsed them out and the water drained to the bottom of my hot tub. I then sucked that water out. I then reversed my shop vac and blew out all the Jets, and then sucked that water out. So I felt like I had it rinsed out pretty well. I have filled it, and after I turned on all the Jets I noticed some foam still appeared, nothing like it was but still a fair amount. After quite some time I noticed an area probably 2 inches long of some light biofilm which I wiped off with a single paper towel, other than that there is a small amount of foam but it's clean. No sign of biofilm. The foam only appears if I have all the pumps on and it quickly dissipates and disappears when I shut them off. I am not concerned about the foam, my question is the small amount of awesome that is left I'm guessing it's harmless? As long as I don't see any more debris, and my filter is clean, do you think I need to drain the tub again?
Did you add any CYA yet?
At 30 CYA: Minimum 2, Target 4-6, Shock level 12. See Chlorine / CYA Chart.
So do you drop the FC before going in or do you soak in high chlorine water?
1.5ppm FC with zero CYA has a hypochlorous acid concentrations 14 times higher than 3.5ppm FC and 30ppm CYA. That's pretty harsh water to be in. I hate going in my attached spa unless the FC drops to a low value or else I can smell the chloramine form on my skin....yuck.
Either way, enjoy the squeaky clean plumbing. Hopefully there are no snakes in your hot tub ...
Matt, I am definitely getting old as proof is in my poor memory. I did add the CYA to my hot tub prior using the sock method. I remembered doing it before when I tied the sock in my filter compartment, So I did have CYA in my hot tub, I just forgot that I added it.
Another example is couple of weeks ago I left my outside gas grill on overnight as I usually burn it off after I use it. Luckily I had the burners on low so it just ended up with a good cleaning no damage. [emoji30] sucks getting old. GEESH
Basically what Gerry told me was that mixing 2oz of Ahh-Some gel in a gallon of water creates a diluted version of Ahh-Some. By adding about 2oz (depending on size of tub - you want the bubbles to dissipate after about 20 seconds of turning off your jets). I have a 340 gallon tub and use 2oz. This will help keep your lines cleaned out and prevent build up.
Curious to know if this maintenance dose causes any build up of suds/bubbles.
I just did the purge, wipe, clean, and then did an extra fill of clean water which I ran and drained. I have just filled my tub and balanced the water. The water is perfectly clear, and when I run the jets, there is no evidence of suds or bubbles like before. I am very happy.
If I were to add the maintenance dose of Ahh Some, say once a week, would that cause a build up of "product" in the water, and cause foaming and such?
I have been doing this since last September with a fresh flush and fill last November and this past May. I did not see a build up bubbles - even at the end of the long winter until I could flush and fill. In all honesty, the water stayed much more stable and clear. Ahh some has a sister product called Hot tub Serum. The maintenance does solution is the hot tub Serum. Gerry explained it causes micro purges and the dichlor / bleach kills of the small particles of the biofilm that is released. If you see bubbles for more than 15-20 seconds after everything is suddenly shut off - reduce the amount used or skip the next weeks dose.
