This is a totally different type of foam then what the algaecide generates. It's very greasy and scumy. I tightened the grids really good so IF that was the issue it should resolve itself. You raise a good point about the filter somehow allowing excessive aeration except that if such is the case, with the grids now tight, the foaming should have stopped.
You also raise a valid point about sticking with Baq. As stubborn as I am, I do have to agree. Guess that's why I still use a 1972 Cub Cadet to mow my lawn that needs a pan under it to catch leaking transmission fluid, and also probably why I drive a '95 Buick Riviera that is on its third engine! I don't give up easily.
