I'm new here and think this site is great. I've learned so much about pool chemistry and feel I have a good idea on how to keep my pool trouble free.
Does anyone have a Compupool CPSC SWG installed? I'm having one installed on my new pool. The online manual is not very helpful. It shows that there is a built in timer for the unit and it seems like it may actually be able to control the pump as well. A call to the USA headquarters was not exactly helpful. First they said, Yes, it can control a 220V pump, but that the CPSC and the pump should be tied into a standard mechanical timer. So I asked what was the point of the built in timer. They said only for someone who ran their pump 24 hrs a day. Then I asked, so why can it control the pump? They really could not answer.
My pool builder is installing it per the page in the manual that shows it hooked with the pump to a mechanical timer. However, I'm going to explore the option of using the CPSC as a timer to control the pump - either directly (as can be assumed from the manual), or indirectly through a relay. But if anyone has one of these units installed, maybe you can investigate. How is yours installed? Have you used the timer?
Thanks
Thanks
