I moved into a home in December and the pool needs work. I see chipped and blistering plaster, broken and chipped tile, and some cracking.
I know it needs to happen sooner than later, but I have no way to fund it right now. I do wayyy too much research on things, so starting now to develop a plan.
question is....
Q1: with the 1.5" plumbing throughout do I attempt to redo plumbing. I'm sure that adds an extraordinary cost since I'd like to save as much existing deck to keep costs down. It's not a small pool. Approx 18x49. Old inspection by texsun says 45k gal.
Q2: I will say the spa is closest to pad, and looking under the deck by spa I can see some plumbing. So do I replumb spa only ? (Right now spa and pool on single pump. I'd like to use single heater to switch pool OR spa heat.
Oh, skimmers need replacement too. Splitting at top (horizontally) by base of deck.
question is....
