Thread: Reno suggestions for fountains
    Apr 2017
    Houston
    182
    I have these fountains, that are about 18" deep, and when the time comes to resurface I'd like to either pull them or modify. I'd prefer to not make such a significant change, but with the spa step between spa and pool the design just plain sucks. It's ridiculous.
    Id also like to add a sun shelf / Baja or whatever.
    Anyone with a good idea?
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    Re: Reno suggestions for fountains
    Demo the fountains and use that area - plus the area between them where those steps are - connect it all and make a big tanning ledge around the hot tub, then some steps off the ledge down in to the pool. If the bottom of those fountains are 8 to 10 inches below the surface of the pool they are just about the right depth - wouldn't take a tremendous amount of construction.
    Greg -
    11K gal, IG Pebble Sheen (Aqua Blue) with sun ledge and attached spa, Pentair Intelliflow 3050 VS/SVRS (3HP), Pentair ET 8 with Screen Logic, Pentair Racer with 3/4 HP booster pump, 400KBTU Pentair Mastertemp, Pentair 60 sq ft DE filter, J&J Intellibrite LED in spa, Zodiac Nature 2 (not used), Stenner pump/liquid Chlorine, build completed in August 2015
    Apr 2017
    Houston
    182
    At 19.5" deep, from the spillway water level into the pool, that's about 9.5" deep into the pool. So it looks like the fountains are 9.5" below pool surface.
    45,000 gallon (18x49) in ground plaster in Houston. [Gallery]
    2HP Hayward Northstar Pump, Hayward DE 6020 (60sqft) filter, Pentair MasterTemp 400k BTU heater, Pentair SuperFlo 1HP -340038 water feature/fountain pump
    Pentair Easy Touch 8 w wireless remote, Hayward TigerShark QC, & Taylor 2006c
    Apr 2017
    Houston
    182
    adding photos:
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,150
    Your right. That is a ridiculous step design. Agree that the transformation of those areas to a ledge would be very nice.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Apr 2017
    Houston
    182
    Really impractical, and I worry about someone tripping on the deck too. Riser is like 10-12".
    Anyone with ideas and some cheap photoshop skills up to help visualize changes?
