Results 1 to 7 of 7
Thread: Showing CCs for the first time of the year
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    615
    I put solar cover on Sunday. Water has been testing perfect everyday. This morning while testing, the water felt funny when I stuck my arm in to get the test water (wife says Im crazy). FC was 6 and CC was .5. That is a first for me this year. I checked CYA on Monday and was in the 70 range. SWG is not on yet. Is this solar cover messing with my water?? Water temp is 75.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,319
    Re: Showing CCs for the first time of the year
    With the cover on, the sunlight can't break down the CC. It's real common to see a little CC right after the cover comes off, but it will be gone in an hour or two. .5 CC counts as zero around here.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Your wife is right, sorry.
    A cover can inhibit the breakdown of CC a little. But most importantly, RELAX. A reading 0.5 is no worry...promise. It will go back to zero.
    Essential Links:
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    615
    Ok......I'll try to relax, Thanks!!!!
    Mark
    Jul 2015
    Central Valley CA
    1,171
    At least a few times a year I get the same thing just after pulling the cover off. I swear I can even smell a slight hint chlorine but that is probably in my head because I know what CC smells like from my public pool days.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, 320 SQ/ft Powerstrip solar, Stenner pumps for chlorine & MA connected to Smart Life WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    615
    My cover is still on. The wind is supposed to gust to 35 mph today, so it maybe off after while......HA
    Mark
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    126
    Quote Originally Posted by atttech-2 View Post
    Yes! Me too! I start to freak out and ask everyone else if they can smell it. Then I break out the tests lol
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
