Hey everyone, so glad to find this site. I opened my pool and discovered my water was a lovely shade of dark green/black. It did look like this last year. I will never cheap out on the chemicals again. I went to the less pricey box store instead of my normal pool store...anyway here are my issues
1. last year we had bugs blowing into the pool from the return so we did a sand change this year. Hooked it all up and every thing appared to be woring fine. Added my chemicals last if the cheap algiecide and 5 lbs of the 99% instant chlorinating granuals (disolved in warm water) I also had 3 gallons of liquid chlorine I added. Water is crazy dark but I could see the bottom if I looked hard enough untill the chemicals hit then it turned cloudy and green gray. I tested my ph and it was at 7.4 and everything but chloine seems to be in line.
2. nothing to now but wait right..... well I was keeping a eye on the skimmer basket because it was filling up pretty quick (my cover was in pretty bad shape this spring lots of small holes) did my best to fish out what i could with my net. the filling up of the skimmer basket had gone back to a normal rate when I left it last night. I get up this morning and go to check the basket, turn off the pump dump the basket and turn it back on and now water is comming out the backwash.... I have read up on the spider gasket but i just dont think that is it this pool and equipment is only on it's 3rd season. So decide to backwash & rinse just incase some sand or something got in there or someone moved the handle with out turning off the motor. did not work. and now my water has this almost oily look spots in it and all this stuff I assume is algae particals trying to die but my filter is not filtering properly.....
are phosphate removers worth the $$? should i get more aglecide or just keep shocKing the heck out of? should I wait to add more chemicals to until if figure out the filter issue, i just don't want the $ I spent on chlorine to be wasted .....
Thanks in advance for you advice.
