Thread: New Build - Need help choosing options
    May 2017
    NORTH HAMPTON
    5
    Hello all,
    We are under construction and nearing completion of our new gunite pool. It is a large rectangle (18' by 51') with a large 8x12 sunshelf. We will have a Pentair Easy Touch system with an Intelichlor salt water system and a Starite intellipro speed pump. Our pool will have an auto cover and be covered whenever we are not in it for safety reasons (cover is instead of fence). We live in New Hampshire and will have a Starite 400,000 BTW HD Heater.
    I need to decide two main things:
    Easytouch 4 vs 8
    Whether or not to get the Intellichem chemical control.
    I also need to decide (later) whether to go with Screenlogic 2 or an Autelis sytem. We will have ethernet out by our little pool house and I believe can add either one later.
    We decided against an Easytouch indoor control. I need to learn about pool chemistry and how to maintain our SWG best. Is the Easytouch 8 necessary? We have a separate hot tub so there is no spa to automate. The biggest question is for or against the Intellichem. Thanks in advance for your help!!
    Amy
    Amy
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    656
    Re: New Build - Need help choosing options
    We added IntellipH on our current build along with Intellichlor. Makes maintenance pretty easy. EAsytouch 4 will be pretty used up. Go with 8 if you are planning other automations like yard lights etc.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
