Currently my CYA is 50 and I've been pouring about 64oz of 12.5% bleach in daily to keep FC at 6 (14,500 gallon concrete pool). It seems a lot to me but maybe I'm just not used think liquid chlorine stuff as I just switched off pucks a couple weeks ago. All my other chemistry numbers are in check and water is crystal clear. When I have been checking every morning I am getting FC reading of only 1 which means I am losing 5ppm every day. That seem plausible? I would like to only be adding every other day as every day is kinda of a PIA, the pucks did have that going for them. Also with high CYA will the FC still show up on test even though it's not being used because of so much stabilizer of does the high CYA cancel out those FC readings?
Thanks for your help
