Thread: Adjusting TA
    May 2017
    Morris Alabama
    15
    Adjusting TA
    I'm new to pool ownership. Got my second results and they are
    FC 7
    CC 0.5
    pH 7.2
    TA 130
    CYA 40
    Pool math says to lower ph. and aerate to lower TA. How long do I need aerate?
    26K GALLON, IG, 1HP PUMP, VINYL LINER, CHLORINE.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,994
    Re: Adjusting TA
    Welcome
    Aerating will not lower your TA. Using muratic acid will lower TA and PH. I would NOT chase a TA number if your PH is stable. I'd be concerned about cc in the test though
    How are you testing and chlorinating and what does your water look like?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Re: Adjusting TA
    Your pH is already low. Don't add any more acid.
    I wouldn't even bother trying to aggressively aerate it to drive pH up. It'll rise soon enough. As it says in the article "You shouldn't lower TA just to reach a target number."
    The TA recommendation is 50-90+. Which means if you're below 50, you pick a number between 50 and 90 as the target and it tells you how much baking soda to add. If you're in range -- and you are, because you're at 90+ -- just target whatever the current value is. Nothing needed. Easy.
    May 2017
    Morris Alabama
    15
    Re: Adjusting TA
    Thanks Richard320
