Hi all. First time opening my pool as it was installed last spring.
Everything connected easy, had it running, then I drained some water through the "waste" feature of the filter, but when I turned it back to filter, I couldn't get water to come from the pool into the pump/filter. Nothing. Had the same problem initially too, but it eventually worked. Thought maybe the pump needs to be primed, but i believe it's self priming.
Can't move forward til I get this going.
Appreciate any insight or suggestions.
Thank you!!
John
Thank you!!
John
