Results 1 to 11 of 11
Thread: New Member
    tjwood888's Avatar
    May 2017
    Houston
    4
    New Member
    I'm a first time member and new pool owner. Looking forward to using the forum to answer all my questions and learning from experienced pool owner.
    12,000Gal Gunite Free Form, 1,500Gal Spa, Pentair 2hp Whisperflo, EZ Touch 4, Screenlogics, Pentair Color 5G LED, Pentair Legend Cleaner and Booster Pump, In-Line Chlorinator, 2hp Silencer Blower, Mastertemp 400K BTU Heater
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,314
    Re: New Member
    tj,
    Welcome to TFP... A Great resource for all Houston area new pool owners...
    Nice looking pool.. Good job getting your signature done before your first post!!!
    But... be prepared to be 'educated" about your choice of an in-line chlorinator..
    Thanks for posting,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: New Member
    Welcome!
    You're way ahead of the curve, joining not only before you have a problem but before you even have water!
    If you want to ensure you never have a problem, invest in a proper test kit now, so you'll be ready when the builder says it's all yours now. There's a writeup in pool school or just skip it and head over to tftestkits.net for a TF100.
    We want to see pictures when it's full, preferably populated by a bunch of swimsuit models.
    tjwood888's Avatar
    May 2017
    Houston
    4
    Re: New Member
    Thanks guys, I'll get one of those kits. What's wrong with the In-Line Chlorinator?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: New Member
    Constant CYA additions with every puck you use. It can easily become unmanageable.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Re: New Member
    They add stuff to the water that you end up having to drain to remove. Can be CYA or calcium. Either way it's not a good thing.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    tjwood888's Avatar
    May 2017
    Houston
    4
    Re: New Member
    The pool builder said it was awesome and would help with keeping the pool more maintenance free. I have a friend that is a chemical engineer and questioned the heck out of her about her pool set up and she had one so I figured it would be ok.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Re: New Member
    Is it possible that they were talking about a SWCG and just using an odd name for it?
    Jul 2014
    Bedford, TX
    9,314
    Re: New Member
    tj,
    If you monitor your own pool water and understand the relationship between FC (chlorine) and the CYA (Stabilizer) then using an in-line chlorinator is ok.. The only downside is that CYA does not go away, so when the CYA gets too high, you will have to drain, at least some of your pool water, and refill.
    We are assuming that the type of in-line chlorinator we are talking about is to 3" chlorinated tabs or "pucks"... If what your pool builder is calling an in-line chlorinator is actually a Saltwater Chlorine Generator, then that is a whole different animal... and a great thing to have...
    One of the reasons that most people come to this site is because they let the CYA build up in their pools over time. When this happens you almost can't put enough chlorine in the pool to keep it from turning green.
    When using pucks for chlorinating your pool, you normally have to add packets of "shock" to your pool once a week.
    When using pucks for chlorinating your pool, your pool with often smell like Chlorine, the same smell as a public pool.
    When using pucks for chlorinating your pool, you have to spend half your life in the dreaded Pool $tore... Buying things you don't need.
    tjwood888's Avatar
    May 2017
    Houston
    4
    Re: New Member
    It's the Pentair Rainbow 320. Thanks for the info, I'm glad I joined it looks like I have much to learn.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: New Member
    Hey TJ,
    Nearly Everyone came here to learn this stuff, so no worries. In-line chlorinators are great, just not as a now and forever sole source of adding Chlorine for the reason others have metioned. Later this summer you'll see a slew of people joining and discovering they have over stabilized their pools, often for this exact reason. Glad you found us, and hope you enjoy your time on TFP.
    Essential Links:
