Results 1 to 7 of 7
Thread: iAqualink 2.0 - PDA only??
    Apr 2015
    Allen
    61
    I'm a little confused. Does this mean I'll have the pda and/or iAqualink app?
    Dig 4/12/17, Gunite 4/19/17, Deck Installed 5/2/17, Plaster 6/12/17
    13,000 gallon, 24 x 19 rectangular pool/spa, platinum quartz plaster, travertine deck with raised beam in sloped yard. Polaris 3900 Complete, Jandy vsp 2.7hp, Jandy JX1400 Natural Heater, Jandy PDA PS6 (Pool/Spa), TF-100 Test Kit.
    May 2016
    Woodland, Ca
    235
    Re: iAqualink 2.0 - PDA only??
    On my system the PDA was installed by my pool builder and when I added the iAquaLink, the iAquaLink was essentially a fancy on/off switch with no programming ability and no ability to change pump speeds. I found out that the CPU I had installed was for pda only, I then upgraded the CPU to one that fully supported the iAquaLink but turned my PDA into a fancy on/off switch.
    They may may have a CPU that supports both fully, ask your pool builder and let us know what you find out. Maybe one of the experts on here will have a better answer for you.
    Build Video 2016 -- Solar Pad 20.5K gunite (37'x15') rectangle (3.5'-7') deep-- MicroFusion Laguna finish -- Jandy VS pump, cartridge and iAqualink RS -- Polaris 360 Black -- 2 Laminar jets -- 2 nichless 30w color led -- 550sq/ft Heliocol solar -- Soft water auto fill -- Stenner 17gpd
    Aug 2014
    Houston tx
    2,542
    You could try downloading the iAquaLink app and see if it works.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,259
    Nate,
    It appear to me you have two antennas. I suspect one is used to communicate with your "PDA" remote and the other is used to communicate with your WiFi devices, like your phone.
    But that is just a guess by me, as I am for sure not a Jandy expert..
    As others have said.. why not just ask your pool builder???
    Apr 2015
    Allen
    61
    I'll ask when I see him. The 2.0 antenna just shown up last night. It was my understanding that I had to pay extra (or it wasn't included in my contract).
    Jul 2014
    Bedford, TX
    9,259
    Nate,
    Maybe because you live in Allen, they just assumed you could afford it...
    Apr 2015
    Allen
    61
    Very likely😊
