Results 1 to 9 of 9
Thread: using too much chlorine
    Aug 2013
    Stockton, Ca.
    23
    I just pulled my pool cover off a few weeks ago. It just started warming up in California here. I have been putting a gallon and a half chlorine daily. Whats up with that? PH is fine. I have not checked others yet. The water is crystal clear
    Chris M. 20k, inground, defilter, pebbletek, 1hp motor,Tiger Shark QC, TF-100, switched to liquid chlorine 3 years ago LOOOOVVVVEEEE it!
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: using too much chlorine
    What's your CYA level?
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    40,833
    Yup, need to know the CYA. What is the liquid chlorine strength?
    What does thev water look like?
    What test kit you using?
    Feb 2015
    Chandler AZ
    1,061
    I see you listed the TF-100 testkit. How old are the reagents in that kit? Post up a full set of current test results from that kit.
    FC
    CC
    TA
    CH
    CYA
    Water Temp
    An OCLT may be warranted - Perform the Overnight FC Loss Test (OCLT)
    Also, add your location (city and state) so we can better assist you - Edit Profile - Add City/State
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Beyond what the others have posted, is that chlorine left over from last year? Even if you just bought it from a store, it could still be last years and is essentially expensive salt water.
    Aug 2013
    Stockton, Ca.
    23
    TC 5.5
    TA 80
    Calcium Hardness It comes out light pink- does that count at red?
    (Calcium = 150) ( how do yopu know it has copper? Directions say if pool contains copper add 2 drops R012 before
    adding R011L)
    CYA - it's always clear. It never gets cloudy. It goes all the way too top and I can clearly see black dot. Did it twice.
    Ph - 7.8
    My water is crystal clear.
    ps the neighbor cut down trees that now give me sun till 7 pm every day. Before sun was blocked by 1:30.
    The kit is two year old.
    40,833
    2 years is starting to push the life expectancy of some of the reagents in that kit. I would recommend ordering some refills.
    Sound like you have near 0 CYA. So that means you can lose 50% of your FC in a hour of noon sun ... and likely lose it all every day.
    Raise that up to 30-50ppm (depending on your location ... add it to your profile please )
    Aug 2013
    Stockton, Ca.
    23
    I'll give it a shot. Thank you. When I do pool calculations it says to add 326 ounces of calcium chlorate for my calcium hardness. Does that sound right??
    Seems like alot.
    40,833
    That seems like a reasonable amount of calcium . I would just Target 250 PPM
