Thread: Delayed opening
    May 2016
    Ste-Anne-des-Lacs, Quebec, Canada
    30
    Delayed opening
    We are moving the filter and the pump but before we can relocate them, a retaining wall has to be built. It is going to be at least another week if not two before we can reinstall everything and open the pool. What can we do in the mean time so the pool does not become a swamp?
    I remember reading that as long as the water temperature is below 50F (or was it 60F?), nothing will grow. What can I do if the water temperature starts to rise? Can I had some bleach and manually mix the water? Would it make a difference?
    Any recommendations are welcome.
    Above ground pool 15' x 24' oval, 48" deep at average level => 9300 gallons/ 35200 liters
    Hayward sand(glass beads) filter, Hayward 1.5hp 2-speed pump
    WSP wood-burning heater and Nirvana F1000 heat pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Delayed opening
    Under 60 should be ok. Adding bleach and mixing it around is good too.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Delayed opening
    Stir your water up with a pool brush, or you can use a submersible pump to just recirculate the water in the pool. Once the water has been mixed up take your chemistry readings and add chlorine to the pool to bring your FC up to proper levels. You have to mix the water before you test and after you add any chemicals to get proper readings and dispersion of the chlorine.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: Delayed opening
    That might be a bit of an over statement............but it will be at a MUCH slower rate.
