Results 1 to 7 of 7
Thread: installing foam cove and base, Do i need a base ?
    May 2017
    Gainesville , Georgia
    11
    I'm in the process of installing a 27' round above ground .
    When using a foam cove , do i install the cove all the way at the bottom of the pool, on the bottom rail at ground level and then add the 2-3" of sand base ? Which will then cover most of the cove with sand , or do I install the 2-3" of base sand and level and then install the cove on top of the sand base ? if using a foam cove , Do i still need a 2-3" sand base ?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: Question about installin cove and sand base
    Do you have instructions that specifically spell that out, or do you think you might be looking at either a sand cove OR a foam cove?
    May 2017
    11
    im for sure installing the foam cove , i already have it , (foam cove , foam wall roll , liner pad ) but the pools instructions say *nothing* about how to install it in relation to the base . and instructions has no mention of a base at all . i guess they assume its common knowledge maybe .
    the manual is online if you want to look and see if i missed something " azor above ground pool manual"
    https://www.google.com/url?sa=t&rct=...ix0pxnI8eUn3zg
    the manual seems very generic
    27'x54" Azor AGP. Hayward swg , 18" sand filter 1hp matrix pump . 16mil solar cover
    Alps Everest spa 455 gal
    Apr 2010
    East Texas
    10,152
    I'm pretty sure a foam cove is used in lieu of a sand cove. Why would you need sand there?
    May 2017
    11
    I thought regardless of what cove material is used your still supposed to add a 2-3" base ? is that not correct ? do i simply install the foam cove at the bottom of the pool on the ground and that's it ? if so what protects the liner from the ground (dirt)
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
    Re: installing foam cove and base, Do i need a base ?
    from the pool store or manufacture videos I have seen they do the base sand (floor) and then a sand cove or a foam cove. You don't want to cover the cove with sand. The whole point of it is to keep the liner from slipping under the pool wall. I would think if you cover the cove with the floor you are just back at square one.
    KarenNJ's Avatar
    May 2017
    Newfoundland, NJ
    223
