Results 1 to 7 of 7
Thread: Spa light junction eliminate
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,282
    My spa light has a junction box the sits in the middle of the yard. It is an eye sore and a tripping hazard. I need to replace the spa light as it doesn't work (rusted water inside probably circa 1980s). Is there a way to eliminate this and marry up the two conduits below ground without having to replace the entire conduit?IMG_0533.JPG thanks!
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Spa light junction eliminate
    Short answer: no. I know I've seen pictures of flush-mounted boxes, so I googled and followed a link from an image to NEC Requirements for Installing Pools and Spas, Part 2 of 3
    For luminaires greater than 15V, the junction box must be at least [680.24(A)(2)]:
    4 in. above the ground or pool deck or not less than 8 in. above the maximum water level ( Fig. 2 ).
    4 ft from the inside wall of the pool, unless separated by a solid fence, wall, or other permanent barrier.
    For luminaires less than 15V, you can use a flush deck box if [680.24(A)(2)]:
    An approved potting compound prevents the entrance of moisture.
    The flush deck box is at least 4 ft from the inside wall of the pool.
    If your pool lighting is low voltage, then you could dig things up and install a flush mount.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,282
    What I want to do is to join the two conduits eliminate the junction and put in a light with a cord long enough to reach from the spa to electrical breaker panel at my equipment pad.
    Or if a junction is needed put it closer to the electrical panel instead of out in the yard without having to dig a whole new complete trench from the spa to the electric panel.
    Karen
    jza1736's Avatar
    Apr 2017
    Greenlawn, NY
    364
    You can put it close to the panel. The requirements are minimum measurements.
    17,000 gal 20' x 34' Polymer freeform pool, All Hayward products: Aqua plus 16v w/ SWG & Aqua connect, Summit 140k btu heat pump, Tristar VSP 1.85HP, 1 Universal Colorlogic light, 1 320 Colorlogic light, 1 4' lighted Sheer Descent, 2 Pentair Magic Bowls
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,882
    You need a junction box on 120v lights but you can move it near your panel. Keep in mind that you must also run a new #8 ground wire in the conduit (if the conduit is a non-metallic material).
    The trouble you are going to have is splicing the existing conduit sections together and making them watertight if they are made of anything other than PVC.
    -Brian-
    Pool/Spa, Pentair Equipment
    Sep 2016
    ty/jk
    5
    What is the reasoning behind the 8 inch box height? I've seen this time and time again, and never truly understood the purpose behind the code.
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,882
    The conduit is flooded so the height eliminates the chance of water entering the area where the electrical splices were made.
    -Brian-
