Results 1 to 9 of 9
Thread: Wouldn't my pool empty if there is a leak in the deep end ?
    May 2017
    Schwenksville
    3
    18x36 inground vinyl
    8ft deep end / 3.5ft shallow end
    I have a pool person who has been trying to find a leak. He is now convinced that the leak is at the bottom of the pool.
    I'm having a difficult time with that idea.
    The water level over many months has not went lower than about a 1/2 inch above the bottom of the skimmer.
    Wouldn't the pool drain to the point of the leak over many months ?
    There was a leak that he found that was in the shallow end and was patched. I'm still not 100% if that was actually a leak because again wouldn't it drain to the leak level ?
    Thanks
    JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Wouldn't my pool empty if there is a leak in the deep end ?
    It would indeed drain to the level of the leak if there were no water added from rain, manually, auto-fill etc. If the water table were high, it may take a long time to drain all the way to a low leak, but you'd likely see problems with liner float/wrinkles before that happened.
    Isolated Spa - 345 Gallons
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,778
    Quote Originally Posted by maestro7879 View Post
    The bottom of the skimmer inlet (throat)? Or the bottom of the skimmer proper?
    I would look at the connection between the liner and the skimmer for a leak if it were 1/2" above the bottom of the skimmer inlet.
    Factory Warranty Station for:
    Jandy/Zodiac, Pentair, Sta-Rite, Raypak (Rheem, Rudd), Polaris,
    May 2017
    Schwenksville
    3
    The water is 1/2" from the bottom of the skimmer throat. The skimmer gasket was replaced and silicon was used.
    I've watched the pool guy test it with dye multiple times and it doesn't appear to be leaking.
    He's still convinced the bottom of the deep end is leaking.
    18x36 vinyl inground
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,319
    Water seeks its own level. Stop.
    If the leak stops at the same place consistently, the leak is at that level. It doesn't have to be at the pool, either. It could be a lousy plumbing joint closer to the pump but at that same level. Do you have a built-in overflow? Maybe the stand pipe is cracked or broken?
    I'd start by looking all around inside the pool at that same level, especially near seams and where the steps meet (if any) Then look at the skimmer. See any cracks? Look for especially lush grass or weeds near any return plumbing. Lastly, dig around the pipes near the pad. Is the ground wet?
    Nov 2011
    Moberly,MO
    1,031
    When water inside the pool equalizes with ground water it will stop leaking. It does not matter where the water is leaking from. If there is a drain field under the pool that can change the amount of water that you can lose.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,778
    ESPECIALLY if the gasket was changed, inspect the throat area again. If the water level is near the skimmer throat, go ahead and fill the pool back up. Then take some dye, test solution works well, just don't use it anymore for water testing after, and see if the replaced gasket joint is leaking or drawing any of the dye.
    We have same size/kind of pool. From experience, if there's a leak in the deep end it will continuously drop till it gets to that point and there will be no doubt. Pretty quickly to, when we finally found it there a slice like spot no more than an inch long! Hopefully you are getting charged for the searching. Our pool can lose half an inch to evaporation in a day.
    Nov 2011
    Moberly,MO
    1,031
    Just replaced a liner on Saturday the hole in the vinyl was a foot below the water line. With no way for water to get away from the pool and a hydrostatic relief valve water was returning via the valve and the pool did not leak down below the hole.
