Hi there. I looked up metal magnet and its "HEDP" ( phosphonic acid with etidronic acid) the same as the sequestrant products typically recommended here. Sparkle up appears to be pure cellulose.
Lynner, some folks flush the antifreeze back into their pools without incident, but we HAVE had 3 simultaneous threads occur around the same time (late spring) in the past that a former resident chemist had tested, and where antifreeze did indeed seem to cause crazy cc spikes. Other things, such as pesticide overspray, fertilizer blow in, etc. can also cause heavy chlorine demand and subsequent high ccs. Does anything like that resonate?
Is your pool cloudiness visibly clearing at all? I'm assuming you're filtering 24/7 per
SLAM Process instructions, right?
So, two issues seem to be that FC is not holding and pool remains cloudy. Logically, those two things should be related
If its nascent algae, turning to white cloudiness would suggest dead algae but the filter should be clearing it at least a little every day. Also, the incredibly high cc readings lately are suspicious of another variable in play - which doesn't necessarily mean that situation A - as in Algae - isnt also still in play.
First, when you dose, with CYA stable at 50 (you reported adding 4 lbs and then getting a reading of 50 from 5 prior) in your shoes I'd dose UP - eg. maybe 24 ppm instead of 20 to see if it holds for 4 hours. Don't want you to nuke the pool but I also don't want to see you languish unnecessarily either.
Any time FC falls below the slam level, in effect you're not actually slamming. So if you dose to 20 at 8 am and if by 10 am its less than 20, for the next two hours the algae gets ahead. Sometimes that's where folks get stuck on a slam. You want it not to fall below 20. If you do this for a few days, I think you'll turn the corner, even if the FC is also fighting something chemical in the water as well.
Regarding the cloudiness, you've mentioned using the sparkle up last year and again this year. I'm actually wondering if its possible your sand is gummed up and needs a good flush. The way to tell is to remove the multiport, scoop up some sand, roll it between your fingers. If it sticks or rolls smooth, its worth a deep clean running the hose to overflowing for a while.
Hang in there and post some pictures if you're able. Sometimes seeing helps
