Thread: Dichlor Brand?
    May 2017
    Fresno, CA
    37
    Dichlor Brand?
    Which brand Dichlor do you like and where do you get it?
    Bestway AG Vinyl Oval
    18' x 9' x 48" ~ 3,548 Gallons
    Sand Filter & Solar Heater
    Elite Spa 86" x 87" ~ 350 Gallons
    TF-100 Test Kit
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,323
    Re: Dichlor Brand?
    Jake,
    You do realize what you are asking is a little like going into your local Fire Department and asking for the name of the best arsonist..
    Most people on this site use Liquid Chlorine, plain bleach, or Saltwater chlorine generators...
    Let's see if we can get someone with a more positive response to chime in..
    Sorry... I had assumed this was for your pool.. I am Spa illiterate.
    JoyfulNoise's Avatar
    May 2015
    14,094
    Re: Dichlor Brand?
    If you need to use dichlor in your spa (... because you would NEVER use dichlor in your pool, right??? ) then the brand is really irrelevant. You simply want to make sure that you are getting pure dichlor without any additives in it. Some of the combo products (like the Clorox line of pool and spa chemicals) have dichlor in them but it's usually only about 50% or so. The rest is made up of baking soda and borates to help counteract the acidity and, heaven forbid!, copper sulfate to act as an algaecide.
    Stick with whatever is the cheapest and purest stuff you can find.
    Matt
