Thread: Ascorbic acid treatment Question
    May 2017
    North Wales
    5
    I just got a new liner and new pump this year, so I have all new water (filled partially from a truck, partially from hose) There is no metal in the new water now, but it was very high all last season, so I do have some existing staining on the fiberglass steps. I wanted to a small dose of the ascorbic acid treatment to get them looking bright white again. There is no chlorine in the pool yet, as I just finished filling it last night. If I were to do the ascorbic treatment, should I still not shock for 2 weeks? How do you recommend going about this since I want to get some chlorine in the pool soon, but I also think this is an ideal time to treat the steps
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Ascorbic acid treatment Question
    Welcome to TFP!
    You can add chlorine to target level for your CYA, FC/CYA Chart following the AA instructions. Just don't shock. Is there a reason why you need to?
    Here is the AA instruction, Ascorbic Treatment to rid Pool of metal stains
    May 2017
    North Wales
    5
    No, I don't think there is a reason to shock at this point. I think getting it up to an operating FC level (from 0) is the goal. I figured that would take more than just pucks in the chlorinator, so I was more just asking if it was OK to use larger amounts of direct chlorination (likely liquid chlorine or bleach) to get it up to 3ppm or so. I think this answers the question. Thanks!
    DFW, TX
    24,974
    Yes, it is definitely fine to use bleach/liquid chlorine to raise FC quickly.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,837
    Edam, if its steps only, here's my trick that worked like a charm without the whole full AA treatment a pita:
    1. Get a pound of AA (or less...I used less than a quarter cup) - you can order same on Amazon for cheap
    2. Buy a cheap dishwashing wand that has the hollow handle for putting dish soap in. Instead of loading with dish soap, using a funnel, fill about halfway with AA powder and half with water. cap.
    3. Rub the brush on the steps, and anywhere else for spot treatment.
    4. Follow with a quick splash of sequestrant on the steps right away, eg 4-6 oz, just to immediately sequester any iron released.
    Five minutes later, you're done
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
