Thread: Pentair 320 Auto Chlorine Feeder Always has water in it?
    Apr 2017
    Republic, MO
    23
    Hey Guys. My pool has a auto chlorine tab feeder on the pipe to the pool return. So far I have just been adding bleach to the water instead of using the chlorine tabs. Not sure if this is a more effective method or not. Anyway, my Model 320's valve is set to off, but the unit is still half way full of water. Does anyone know if that is normal?
    Attachment 60584
    16,100 gallon AG pool; 45" x 27' round; Installed July 2009
    Waterford Systems Sand Filter - JSAL180F; Pentair Dynamo 1.5 HP single speed pump
    TF-100 testing kit; Filled with city water - no water restrictions.
    30,955
    Re: Pentair 320 Auto Chlorine Feeder Always has water in it?
    Of course, the water in the 320 doesn't matter because you have no tabs in it.
    Does it fill to the top when the pump is running?
    Are you thinking of using it?
    Apr 2017
    Republic, MO
    23
    Yeah, I know it doesn't matter now with no tabs, I just wasn't sure if it was an indication of malfunction. That height is what it is at with the pump currently running.
    I'm on the fence about using it. In the How To Chlorinate Your Pool page on this site it says that using Trichlor tabs (which is what I have a giant bucket of) will add CYA to my pool to the point it renders the chlorine ineffective. I obviously want to avoid this, so I'm hesitant to use it.
