Results 1 to 7 of 7
Thread: Intex pump isnt running at full power
    May 2015
    Odense S
    28
    Hey fellow swimmers.
    Im from Denmark and we are nowhere near ready to jump in our pool.......heatwise But we just filled the pool a couple of days ago. All winther it has been half full of water with no cover on, so the water has been a little dark.....or very dark, depending on who you will ask.
    We are about to lower the PH from 7.9 to around 7.2, so we can get the clorine to work.
    Our real problem is the power on our pump. We have a 2800gph Intex pump. Normally its running really well, but from the very start this year, it has been running with low flowingpower. When you look at the needle in the "meter", its pointing "late yellow" so its almost in the red area. If I put on the Intex bottomcleaner, it can barely run that. Last year, it was running across the bottom like it was on fire.....now barely moving at all.
    When I had the same problem last year, it was allmost allways because the outlet in the pool had a lot of leaves and stuff sitting on it....but thats not the case here. Can anyone tell me where i might find the problem??
    Jun 2014
    17,340
    Re: Intex pump isnt running at full power
    Just to make sure we understand ...... are you sure it's a "power" issue, and not simply a suction or water flow issue? For example, as dirty as the water appears to be right now, is there any chance the filter is simply overloaded with junk and needs to be backwashed or better yet - deep cleaned? Deep Cleaning a Sand Filter
    May 2015
    Odense S
    28
    Im not sure of anything. But just before we started the pump this season, we looked into the filter to check the level of sand. It was fine and it was clean. It doesnt seem like there is something wrong in there. Im not sure where I need to look. I have been backwashing and rinsing quite som times now. It doesnt seem to help. Thats why I wanted to check in here....
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Sometimes when it seems like a filter is clogging more than usual it is because there is a beginning algae bloom. That is often the first sign. Try doing an Overnight Chlorine Loss Test to see if there is something growing in the pool.
    May 2015
    Odense S
    28
    Thanks, I will try that
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    With low flow and a high pressure on the gauge, I'd go for a filter cleaning/backwash. It would be really helpful if you filled out your signature so we'd know what type of filter you have.
    May 2015
    Odense S
    28
    Ive been doing a lot of backwashing, and it seems to do the trick. Its getting better and better, so Im a happy camper
    16Ft X 48In Ultra Frame - 2800Gph Krystal Clear Sand Filter Pump.
