Thread: Need recommendation for slippery deck
    Jan 2013
    Southern CA
    50
    Hi! We have travertine tiles on the patio that were sealed with Miracle 511 sealer. This has turned into quite a dangerous area when enough wet kids drip on it as they need to go into the house to use the bathroom. So much so that I have to lay out towels and rugs every time we have a pool party (it's a big area so UGH!). There are some anti-slip products out there but according to instructions you have to strip off the sealer, but called Miracle and was told theirs can't be stripped cuz it's a penetrant. Anybody else with this problem and found an anti-slip solution? Any recommendations will be appreciated, thanks!
    May 2015 completed- 50'x30' beach entry(26'), two 50' swim lanes, diving board, jump rock, 4'-9.5' depth, 40K+gal salt water, Pentair,Screen logic 2 mobile for intellitouch., intellichlor and intellichem automated system. Jacuzzi JLX cuz we rarely used the last in ground spa :)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,325
    Re: Need recommendation for slippery deck
    Maybe ask them if you can add an anti-slip product to their sealer and apply another coat?
    Jan 2017
    Orlando/FL
    124
    I've used a penetrant sealer on my paver deck, and it soaked into the pavers and left nothing on top. It sounds like yours went on too thick and left a layer on top. So you should be able to strip off the excess.
    There are several products available such as this Paver and Concrete Sealer Stripper | The Sealer Store
    20K gal In-ground pool with raised Spa overflowing into pool; two Jandy Sheer Descent waterfalls; Pentair IntelliTouch i7+3, IntelliChlor, IntelliPH, 3 SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, RayPak 406A LP spa heater, Polaris 360 PS Cleaner. Patio and deck lighting by Volt; Volt 600W landscaping transformer; Webber grilling station
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    570
    You might need to apply a product like this...
    Non Slip Floor Paint | Non Skid Coating | Non Slip Concrete
    You can test in a small area or on an extra piece of tile.
    You may also be able to lightly sandblast the surface to give it some grip.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Jan 2013
    Southern CA
    50
    Thanks everyone- will have hubby check these out. Maybe our travertine was too polished to begin with
