Thread: Hayward AquaRite 900 vs SwimPure Extreme
    Apr 2017
    Miami FL
    52
    Shopping around for a Hayward SWG.
    Any differences between AquaRite 900 vs SwimPure Extreme?
    Are these pool store only? I haven't been able to find them online (not the 900 nor the Extreme).
    I found on amazon the AquaRite (it doesn't mention the 900 model) https://www.amazon.com/dp/B002WKJ5ES...ing=UTF8&psc=1
    Do they offer any differences with the non 900 or Extreme versions?
    Thnx,
    13K gal, IG plaster, 1 1/2 HP Pentair WhisperFlo, Hayward C900 cartridge filter, Taylor K-2006 FAS-DPD, Hayward AquaNaut® 200, built around 1979
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Hayward AquaRite 900 vs SwimPure Extreme
    Not sure...getting you a bump up in hopes of an answer...
    Essential Links:
    Apr 2017
    Miami FL
    52
    Quote Originally Posted by Patrick_B View Post
    Jun 2011
    Long Beach, CA
    2,892
    They are both equivalent systems and they both have extended life cells compared to a standard cell of the same size.
