Thread: Newbie - Air in return jets
    May 2017
    Scottsdale Arizona
    2
    Hello all,
    Apologies if this has been posted elsewhere- I did a quick search, but could not find anything that matched my issue completely...
    I bought a house that has an old DE filter, with pump and booster... originally attached to a solar heater.
    Last year we had some issues with the solar heater, and so we were advised to bypass solar.
    Ever since, when the pump turns off we can hear a gurgle. Each time the pump turns back on we get a huge amount of air through the return jets, for about 1 minute.
    I cannot detect a leak anywhere, the pressure shows around 13 psi through the filter.
    The pool is otherwise in good shape, so not sure if I should ignore this, or if it will bring trouble down the road.
    I am very new at managing my own pool, so not sure what other information to offer you... but will answer what I can!
    Thanks.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Re: Newbie - Air in return jets
    How does the air bleeder valve on top the filter feel when you open and close it? Once in a while, mine gets sticky. It seems to seal under pressure, but it will let air in when off.
    Stick a balloon over the opening. If it's been sucked in overnight, you found the source.
    May 2017
    Scottsdale Arizona
    2
    Thank you - just to clarify.... on the top of the filter housing is a pressure gauge and a small length of tubing.... is that the bleeder valve?
    Thanks.
    Richard320's Avatar
    Jan 2010
    20,296
    Quote Originally Posted by alexgwoodruff View Post
    Thanks.
    Yep. The fat collar turns to open. Air or water will spit out the tube. If it's air, leave it hissing until water starts flowing, then close.
