Thread: tile and grout question
    Apr 2017
    Southport/NC
    9
    We are purchasing a house with an in ground galvanized steel pool with a vinyl liner- but it is sitting kind of above ground with decking. On one side is an infinity edge that spills about 3 and 1/2 feet down into a basin- the length there is around 20 feet.This side is tiled. We had a pool inspection and one of the items that came up is the discoloration of the tile and grouting. the inspector said the grout has been compromised in several areas and is causing the steel to rust which is leaching out. Now he is saying that the grout can probably be repaired although he said it would not be an easy job. but my question is how do we know how much rust has occurred on the steel? and won't it just continue to rust under the tile? Shouldn't the tile be removed, the rust on the steel treated and then retiled? There is quite a bit of discoloration along the whole wall, so it is not a small job.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    572
    Re: tile and grout question
    Yes to fix it right. You can use Por-15 paint on the rusted steel to seal the rust. It is used on submarines.
    you can remove a small area and look at how bad the rust is....
    to regrout the existing ground needs to be ground out and then replaced with a grout specific to under water applications.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Apr 2017
    Southport/NC
    9
    thank you- that was my feeling, too. Otherwise the rust is just getting covered up and can continue to eat away at the metal, right?
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    572
    https://laticrete.com/~/media/suppor...171.ashx?la=en
    You can research more about laticrete products for pool tile & grout online. High quality product that will not fail.
    ColorQ Pro
    TF-100
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,154
    Should I go for my tiles on the pool floor?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Apr 2017
    Southport/NC
    9
    Quote Originally Posted by blakeusa View Post
    thank you- that link definitely states rust needs to be removed
    Quote Originally Posted by bmoreswim View Post
