Thread: My numbers. Is my TA okay?
    Im confused as to a proper TA level. Below are my numbers. Any help wll be greatly appreciated.
    FC 3
    CC 0
    TC 3
    PH 7.5
    TA 120
    CH 75
    CYA 50
    Foxx IG Vinyl Liner 17x38 Oval 3'-0-8'-6", 24000 Gallons on Bleach, Hayward Sand Filter Hayward Super Pump 3/4hp, TF-100, Active30 Robot
    Apr 2017
    Tucson AZ
    81
    Re: My numbers. Is my TA okay?
    Salt pool? Makes a difference. My goal is 60-80 with my salt pool.
    In-Ground Pebble Tec installed 2005/10,000 gallons/Magna Sweep cleaning system/RJ-30 Circupool SWG/Rock Waterfall/Hayward Ecostar SP3400 VS pump/Hayward Swimclear C3025 cartridge filter/Hayward H400IDL2 gas heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    TA is fine. When the pH rises and you add acid to lower it, pH will also drop.
    3 FC for 50 CYA is too low. I don't see a SWG listed in your signature.
    non swg. using bleach to sanitize
