Thread: CH Test
    Mar 2015
    Georgia
    157
    CH Test
    For some reason adding another drop of R-0011L seems to help me with the color shift to blue. Is there anything wrong with accuracy by adding another drop? Even thought about adding 2 drops of R-0011L to see what happens.
    16k AG Vinyl Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,311
    Re: CH Test
    You're using 3 drops in 10 ml water?
    Yes, you can use 4 or 5. I do.
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Re: CH Test
    Keep adding drops until the color doesn't change...then just don't count that drop.
    Memphis, TN.
    Pool IG, 20K gallon, Gunite. Triton Sand filter, Pentair Pump, Polaris 280, Doheny Discovery Dolphin, Chlorinating Liquid, Rock Water Feature, New Plaster 2015
    Spa 450 gal, Tropic Seas Waikiki 864L, Bromine
    Taylor K-2006
    Mar 2015
    Georgia
    157
    Re: CH Test
    Yes I had been using the default 3 drops of R-0011L with 10ml water but decided to try an extra drop. My CH test has never just crisply turned from red to blue as far as I can remember. Always have a purple before getting there, at least that's what my memory says. My reagent is getting old too though. I have some new on the way.
    Richard320's Avatar
    Jan 2010
    20,311
    Re: CH Test
    Quote Originally Posted by smackdab View Post
    Mine takes a long time to go from red to blue, too. The speedstir helps a lot with the intermediate colors. Another cycle will push usually push it one way or the other.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: CH Test
    You can go 5 no problem. It helps on this test and the same with TA. Put a few extra drops in there and see if it helps. It will no hurt your results at all on these two.
    Essential Links:
