FC 16
CC .5
pH 7.5
CYA 50
Alk 150
Started trying to get my pool blue again last week. Been brushing the pool surface every evening and putting in 2-3 gals bleach to keep it at 16. Every day when I get home from work the water is mostly blue, but extremely cloudy. I know there is pine straw and other leaves in the deep end but it's so cloudy, I can barely see 6 inches down. I put 2 lbs of stabilizer In Sunday and Monday. The first half I put In via skimmer. It took all day Sunday and most of Monday to dissolve with me shaking the sock to help it along. The second half I put In front of a return and it disolved within 3 hours. In the last 2 days a white film has developed and seems to be getting worse by the day.
Should I keep doing what I'm doing, or do I need to do something else?
Do I need to try to vacuum to try to get all the leaves and straw up even though I can't see the bottom or should I just keep brushing daily? Each day I brush, the amount of yellow cloud that comes up is smaller and the water turns less green with each brushing.
CC .5
pH 7.5
CYA 50
Alk 150
