Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Spray Decking, Opinion please!
    JarCar's Avatar
    Mar 2017
    Katy, TX
    89
    Spray decking/cool decking: Pattern or no pattern? Let us hear your opinion!
    This will cover all of the original decking you see on the far right under pergola/cover as well as the new concrete around pool. We have chosen Autumn Tan as the color.
    Thanks in advance! Here is the pic:
    https://ibb.co/kXFsd5
    Played with them in photoshop quickly to help to visualize the two options...
    No Pattern: https://ibb.co/gAwyJ5
    With Pattern - tried to keep scale as accurate as i could, but not sure on the size of the actual pattern and had to overlap areas to finish it off, and do quickly so not perfect pattern.:
    https://ibb.co/fFOpQk
    18.5k gal, IG, Quartzscape Aruba Sky Caribbean, Hayward Cartridge, 2.5HP Hayward Tri-Star VS (3 - Pool/Spa, Waterfall/Slide, Weeping Rocks), Apr 2017 install, Taylor 2006 Test Kit, 6x9 Spa w/Hayward 400k BTU, Hayward Omnilogic 8, Hayward Tigershark Robot
    40,848
    Re: Spray Decking, Opinion please!
    I vote no pattern. Looks too fake imo.
    Feb 2015
    Chandler AZ
    1,061
    I'm with Jason - no pattern. Most of the patterns look fake to me.
    Having no pattern is easier to touch up if you have a woops. Easier to recoat (DYI) in several years if needed also. What brand of topcoat are you considering?
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    40,848
    Make sure they spray the entire texture the same day. They tried to split mine over 2 days and the texture was completely different. Made them redo it and it is closer.......
    JarCar's Avatar
    Mar 2017
    Katy, TX
    89
    Good point, will do, thanks for the heads up!
    Thanks Jason and Gene for the votes!
    chiefwej's Avatar
    Jun 2011
    Tucson
    3,109
    No pattern, for all the reasons previously stated.
    chiefwej
    16x36 rectangular (19k) Pebble Tec play pool/spa, Pentair Intelliflo VS 011018, Super II 2hp (spa), Aqua Rite T-15 SWG, Pro Grid 60 DE, H400 & Heliocol Solar, Dolphin S-300, fill water w/high CH and TA, 50 ppm borates,TF-100 test kit, Smart Home/Alexa pool control
    Meowloud's Avatar
    Mar 2017
    Chattanooga, tn
    199
    No pattern vote here.
    Also, go Autumn Tan to match your house or go light color, diluted color.
    You're in Katy TX. Don't want you to burst into flames.
    ~22k IG Vinyl (Ocean Midnight), Hayward Tristar 3200VSP, Hayward Sand Filter S3103S, Hayward 4.0 LED, TF-100, High-Iron, 7.5 ph Well Water.
    mamasmith's Avatar
    Apr 2017
    Canton, GA
    94
    I vote No pattern!
    UNDER CONSTRUCTION: 544 sq feet in ground shotcrete pool, 3.6' to 6' depth, stone coping. Includes: Spa elevated 18 with stacked stone, Concrete Deck
, 18 raised beam with stacked stone Waterfalls on raised beam wall, Stacked stone on firepit side, 4' Firepit, Flagstone steps to firepit area
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    656
    No pattern..no pattern..no pattern. Did I mention No Pattern?
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    JarCar's Avatar
    Mar 2017
    Katy, TX
    89
    Quote Originally Posted by Meowloud View Post
    Haha that is actually the exact color we chose! It does get hot here, looking forward to having our own pool!
    JarCar's Avatar
    Mar 2017
    Katy, TX
    89
    Thanks everyone for the votes, looks like everyone is for no pattern on here and it was half and half on our Facebook friends vote...some valid points on no pattern, and we have decided on no pattern. A friend mentioned it peels after a while? Is that normal? How often does spray decking need to be re-done?
    Hoping the decking will be done soon so we can get the kids safety fence installed.
    JarCar's Avatar
    Mar 2017
    Katy, TX
    89
    Quote Originally Posted by proavia View Post
    I asked our pool guy what brand earlier as I am not sure, but no response yet.
    Meowloud's Avatar
    Mar 2017
    Chattanooga, tn
    199
    whatever you choose, JarCar, it will be right for your family!
    chiefwej's Avatar
    Jun 2011
    Tucson
    3,109
    If its applied properly and maintained it can last a very long time. Mine is about 12 years now and still looks like the day it was new. But I touch up any cracks or chips as soon as they appear and apply a new top coat every few years. It will peel if you neglect it and allow water to get under the coating and lift it. If you keep it well sealed it lasts. One five gallon bucket of color top coat runs about $100. That and one afternoon every few years, rolling it on makes it like new again.
    chiefwej
    JarCar's Avatar
    Mar 2017
    Katy, TX
    89
    Quote Originally Posted by chiefwej View Post
    Great to know, thank you! We will have to remember to do this!
    Feb 2015
    Chandler AZ
    1,061
    What Chief said.
    Mine is just over 17 years old. New top coat applied every 3-5 years. My top coat is Xcel Surfaces Top Coat - but there are others available as well.
    Gene
    JarCar's Avatar
    Mar 2017
    Katy, TX
    89
    Spray deck finished yesterday! This is Autumn tan and they did two coats. I took a picture of the bucket I saw out.
    chiefwej's Avatar
    Jun 2011
    Tucson
    3,109
    The product they used is made in Lakeland FL. It isn't a bad idea to have some around for touch up, and in a few years you will want a full bucket to refresh and reseal. I would ask the applicator if you can have what is left over in a bucket, and where the local supplier is.
    chiefwej
    Meowloud's Avatar
    Mar 2017
    Chattanooga, tn
    199
    JarCar, that is a sexxxy cool deck there!!! It blends in and doesn't take away from the stonework of the pool.
    Seriously though, that is a great color that accents the home! How is the family liking it?
  20. Back To Top    #20
    JarCar's Avatar
    Mar 2017
    Katy, TX
    89
    Thank you! We are loving it, still some stuff to get done though and pool school.
