Thread: Dolphin M500 Cleaner - Walls
    Apr 2017
    Pittsburgh,Pa
    16
    My Dolphin M500 doesn't get up the wall far enough to clean the water line. I adjusted the handle/float (offset one side; at an angle) but it still doesn't seem to get up high enough. Are my expectations unreasonable (ability to truly clean the water line)? I don't want to chase a ghost, but all indications are is that the machine should be able to reach and clean the water line.
    Also, I tried the various clean modes and used the remote to drive up the wall, but no luck. I called Maytronic and they suggested adjusting the handle. As noted above, that didn't seem to work.
    20K gallons, IG, Vynl, Filter (DE; Pentair FNS Plus Vertical Grid D.E)
    Pump (not variable), Build (June 2016), Test kit (strips,
    SWG (Pentair Intellicor), Heater (Pentair Mastertemp)
    Pentiar Autimation (Sceenlogic controls pool pump, SWG, Waterfalls)
    Dolpohin M500 Ribit Cleaner; Two natural stone waterfalls
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Dolphin M500 Cleaner - Walls
    I've just figured this out for mine.
    There are foam rings on the brushes and mine were worn smooth out. The rings are called climbing rings. I will be posting a refurb thread on this soon. Going into season 4 after three very hard ones, mine was overdue. I haven't figured this out yet, but mine also climbs best after the water is warmer. I have a guess, but not sure yet. If yours isn't old like mine, wait and see if it does better with warmer water. If it is, you may need new rings and tracks.
    Also, and not assuming yours is bad, but if you have some slippery stuff on the walls from being low on chlorine, that may be a problem as well.
    Essential Links:
    Apr 2017
    Pittsburgh,Pa
    16
    Thanks for the response. Mine is not a full season old yet, but I will check. We just opened the pool for the season so the chlorine was low. Great points/insights. Thanks again.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Sure thing.
    Yea, check the walls for slipppery-ness since you just opened and see.
    Essential Links:
