Results 1 to 8 of 8
Thread: How to clean a Hayward T15 cell
    May 2016
    Bethlehem Ga.
    10
    I know I've seen it somewhere but this is my second season with the T15 but the control board is saying the T15 needs cleaning, just want to do it right.
    20 X 40 inground liner pool,1.5 hp Hayward pump, omnilogic automated panel, Hayward T15 SWG, 2 Skimmers and 3 returns, 35,000 gallons, Built it all myself.
    Jun 2015
    Ottawa/Ontario
    357
    Re: How to clean a Hayward T15 cell
    There is a special stand you can buy, that once you put the cell into it, you can pour a cleaner into it for about 2 mins...sorry I don't know the name of the stand!
    18000 IG, SWG, 1/2 HP Tri Star + Solar PV direct DC Lorentz pump, Sand filtrt
    20000 gallon, Vinyl liner IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    It's a timed reminder to check the cell. Only clean if necessary.
    Clear reminder by pressing the diagnostic button for a few seconds.
    Support the site
    May 2016
    Bethlehem Ga.
    10
    Quote Originally Posted by JamesW View Post
    Ok so just look inside to see if there is any scale inside and if not maybe good to go another time?
    Apr 2017
    Maine
    231
    Unless there is scale build up, it's not needed and the mild acid will in fact shorten the life span of the cell.
    Jun 2011
    Long Beach, CA
    2,892
    This should be the process to clean a cell.
    1. Remove the cell and inspect it for scale. If no scale is found, no cleaning is required and reinstall the cell.
    2. If there is scale, use a hose with a stream nozzle and remove as much scale with the hose. If the scale is removed, reinstall the cell.
    3. If there is remaining scale use a plastic or wooden object to remove the scale. Do not use any metal objects as this can scrape off the coatings on the plates. I like to use long wooden Qtip sticks. If the scale is removed, reinstall the cell.
    4. If scale is remaining use a water and acid solution, 4:1 water to acid at the strongest is recommended. If the remaining scaling is light then a 10:1 water to acid ratio is recommended. Soak only for the minimum time to remove the scale. Each time the cell is acid cleaned it will remove some of the coatings on the plates which reduces the life span of the cell. After the acid soaking rinse out the cell with water and reinstall.
    Oct 2015
    San Diego, Ca.
    807
    In my area, the free DIXILINE paint stirrers fit well, to do step #3 above.
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    May 2016
    Bethlehem Ga.
    10
    Ok Thanks all for your help, I removed the T cell yesterday and it looked clean I flushed with the water hose anyways and reinstalled , I guess the timer was just letting me know it was time for a inspection all seems well. Thanks again you guys are awesome , I have learned so much on here and saved me countless $$
