Thread: FlowVis - to add another check-valve or to replace Pentair?
    Sep 2016
    ND
    125
    So I want a FlowVis to know what my flow is - I've read great things about them. Over the course of the winter, I ordered a Jandy retrofit only to figure out later that the PB had used a Pentair check valve (and there's no Pentair retro-fit from FlowVis - the top of the Pentair is bigger, and has a square flapper - they started going down the path of engineering a retro and then aborted due to complications).
    What I have won't work, so I have two options, both of which require me buying a new FlowVis check valve:
    1.) cut out the current check valve, and try to somehow make a new one fit without re-working all of the plumbing between the heater and the SWG
    2.) add a second check valve somewhere
    If I go with #1, any suggestions on how I can do this without having to re-plumb everything?
    If I go with #2, are there drawbacks to having two check valves (I'm assuming that the flapper has some negative effect on flow, so by having two, I'm multiplying the effect?
    Any other suggestions?
    Here's what my equipment looks like today:
    Derek - November 2016 Build, Fill, Cover, and Close. Starting Equipment for the first time in Spring 2017: 26K IG 20x40 Vinyl, All Pentair: IntelliFlo VST 2, Clean and Clear 420 Cartridge Filter, EasyTouch 8, IntelliChem, IntelliChlor IC60 SWG, MasterTemp 250K NG Heater, GloBrite LED lights, Autelis Automation Integration, CoverStar Leading Edge Automatic Cover, Dolphin Quantum Robotic Cleaner, Interfab G-Force 2 slide, Interfab T7 diving board
    22,702
    Re: FlowVis - to add another check-valve or to replace Pentair?
    One problem I see with replacing the existing check valve with another is the injection port prior to the check valve.
    1) You could cut the plumbing right against the check valve cuff, remove the fitting and put a coupling over it. Then extend the loop between the check valve and swcg cell back almost to the wall and install the flow meter/check valve in that loop somewhere.
    2) If you don't want to cut that injection fitting out, you could cut the plumbing right at the elbow after the check valve and extend the loop back to the wall and then put the flow meter just before the swcg cell. Then remove the flapper from the original check valve.
    Sep 2016
    ND
    125
    Quote Originally Posted by Bama Rambler View Post
    The piece just before the check valve is a 3/8" hole that provides a spot for the water to return from the IntelliChem. It can be moved further down the line as long as it's after the heater.
    Your idea of extending it back towards the wall may be the most practical. If I have to extend it, I'll just remove the Pentair valve - seems that leaving it in place would just add more turbulence?
    22,702
    You're right about it adding some turbulence, but it wouldn't be enough to worry about. The only reason I thought about leaving it, was if you didn't want to mess with that injection fitting. You could even put a coupling over the existing hole and then redrill and thread the hole through the coupling.
    Sep 2016
    ND
    125
    I'm getting low-flow messages on my IC60 unless I run my VS at 1500 RPM. The PB put in that loop for the SWG, and I cut in the IC60 this spring, trying to give myself as much straight-line pipe as I could before the SWG.
    The instructions say to have 12-18" to give better flow for the flow switch, so I'm wondering if extending the plumbing back towards the wall may actually help that as well. Right now it seems that I need 1490 - 1500 RPM to get the switch to trip - this is with a filter that's probably pretty dirty right now from construction dirt - so I need to clean that first and see where that puts me in terms of RPM for the flow switch, but extending the pipe may help me in a couple of ways.
    40,867
    As a note, there is no point in having a check valve in that location. If you used a tablet feeder, then sure it is needed, but not for a SWG.
    If you really want the flowvis. You could just remove the flapper in your old check valve and add the new check valve in a different location like maybe before the heater
